I'd like to see the process of opening and closing files streamlined.
Right now on open usine just says "open workspace?". It would be nice if, when the current workspace had NOT been saved, for usine to say "save current workspace before opening?", and if it WAS just saved, to skip the dialog entirely and just open the new file.
Same with quitting. The typical dialog is "save work before closing? Yes, No, Cancel" but usine just says "quit usine?" In both cases, usine is being less helpful than it could about keeping work saved.
These are both very standardized behaviours for computer apps.....
-e
standardize open and close process
- senso
All the choices are made for live situation and MsOffice is not designed to be played on stage!
1) you're not supposed to modify your wkp on stage?
2) the current workspace is automatically saved in the file workspace.wkp.
I know that it can be strange but I don't think it's a big pb?
You'd have to explain to me how the standardized approach would interfere in any way with live performance--it's not obvious to me., and I use usine in live performance virtually every day. Yes, office. Also, cubase, logic, protools, reaktor, etc.
I just believe it turns off potential new users when obvious things don't work as expected, and I'd like to see a more vibrant community, and more widespread acceptance, for Usine. I mentioned this issue because it's a small workflow enhancement that is very easy to implement.
After hundreds of hours, I'm surely used to the current method by now
-e
-e
May I add a little suggestion? Add an option in the dashboard somewhere (I know it's crowded already!), that turns the check on and off. In a way I agree with both of you: On stage, I wouldn't like to get any prompts about saving, when pathcing etc it would be cool.
Nothing I mentioned causes a prompt at saving. Just a more informative one on opening and closing.....
but again--whatever. Not a big deal.
