kvr vst plugin challenge
Unread post by nay-seven » 29 Oct 2009, 22:00
KVR Developer Challenge 2009, if you 're looking for new freeware
check stolon , done by a friend...:
three parallel stereo channel pitch shifter.
It can be used as a classic effect and/or like a instrument driven by the midi keyboard.
Large range effect can be set : robot, vocodizer, chorus...and pitch shifter!
Sample Rate : 44.1 up to 196Khz.
http://www.kvraudio.com/developer_chall ... hp#dc09_56
amiga909
Unread post by amiga909 » 03 Nov 2009, 14:23
i tried em all:
my favs: Harsh Digital Nose, massTURBOtar, stolon (amazingly low on cpu!), Explor3r
artificial
Unread post by artificial » 04 Nov 2009, 10:20
one of my favourites is _02.circles!
I think it is good companion to usine, because it is also made for touchscreen use!
cheers!
amiga909
Unread post by amiga909 » 04 Nov 2009, 11:49
thanks for the heads up artificial
cpu usage is too high imho..
also i dont see how the smaller circles can be controlled with a finger press properly.
makes appetite for new visual controllers made with Usine nevertheless :)
artificial
Unread post by artificial » 04 Nov 2009, 12:04
amiga909 wrote:thanks for the heads up artificial
yeah, you are right, amiga! I just wanted to add this one, because of it's idea! ^^
not really tested it out that much, so thanks for the info!
Users browsing this forum: Bing [Bot] and 27 guests
