As anyone connected several Wiimote to one computer ?
Just wondering is it better (and possible) to connect several Wii to one computer or to connect each one to a different computer and use OSC to get all Wii's info to one computer ?
and how works wi-fi network with usine ?
thanks
PS : You lucky Parisians it's for an installation/performance for les Nuits Blanche and there will be some Usinage in the air
thanks
another question: any1 tried the new wiimote plus controller?
(senso said he's gonna implement it, so it might not work by now)
Helllo Usiners
I've got 2 wiimote and i've saw in the wii module that we can choose 1,2,3 or 4 wii mote
But Impossible to select the first or second remote...
It works fine with one
I hope it could works with 2 or 3 or 4..on the same computer in the same patch
Any suggestions?
best
Simon
Any suggestions?
best
Simon
i've only one wii , so can't test , but what do you mean by " Impossible to select the first or second remote... "
you mean in the module or..?
if yes , have you try to add a fader to the inlet wiimote number..?
Hi Nay Seven
Thanks for your response...
I would say that it's impossible to have the wiimote number 1 and in an other tracks the wiimote number 2
We can't have two different wiimote in two different wii module at the same times.. usine choose only the first for the two module..And ive create a fader to choose wiimote number but nothings happens...
It's strange because it looks like than we can choose until 4 different wiimote...
I keep hope for a solution ! ! !
the bug is confirmed.
send me a mail at contact@sensomusic.com
You'll receive a new version for test.
bug fixed, next release ( 5.25 beta13 and above.)
Users browsing this forum: No registered users and 129 guests
