Do nothing module
dullard
Unread post by dullard » 15 Sep 2009, 15:08
Hi Senso,
It would be useful to have a "do nothing" module to help organise patches. A couple of ways where it would be useful would be to name a signal in a wire that has been created by a complex series of modules where you come back to it and can't remember how it all works and also like a junction box where you have either a lot of signals going to or coming out of a single pin and you need to experiment with the chain so you don't have to keep reconnecting loads of wires.
Cheers,
James
martignasse
Unread post by martignasse » 15 Sep 2009, 15:42
Hi dullard,
I think it's already possible :
drop an empty patch and customise it to make the "passthru/do nothing" patch of your dream ;)
or maybe i misunderstood ?
Hope it help
dullard
Unread post by dullard » 15 Sep 2009, 16:56
Oh yes, I didn't think of using an empty subpatch. I guess that would only have very little overhead.
Unread post by senso » 16 Sep 2009, 08:29
Yes the main idea behind Usine is to build our own stuffs with sub patches.
But I know that with the actual version is not easy to add "comment" on patches.
