Adjusting volume on wires
siegfried
Sorry if this thing was already mentioned here (I didn´t found it via search), bud I´d like to ask if there are any plans to implement this function to Usine. I think this could be great time-saver. I mean volume fader after clicking to any wire in modular view, like in Jeskola Buzz etc, so you can easily control volume at any point of signal flow without inserting some "volume fader" module etc. So what do you think about this idea? It is hard to implement it? Thank you and have a nice day!
Sorry for my bad english :/
amiga909
what has been already discussed is the idea to quickly insert modules via drag+drop and auto-wiring.
personally i dont really see the need for a 'volume fader' for wires since data and audio streams are sometimes the same in usine (volume for data streams?). Buzz is entirely different and much less complex than usine.
- senso
Good suggestion but I prefer the idea of auto-wiring with drag and drop. more general and flexible?
Also, remember that all has a cost in computing: in a complex patch you can have more than 100 audio wires. I means that we can reduce seriously the performances and the memory load.
