Hi folks,
Ive been using the bar recorders on each track creating a kind of "loop station" for each of my vst instruments. Its great for improvising jams. how ever when i save the wav. files from each sampler x2 and then save the workspace for recalling the improvised jam, all the sampler x2 play only one bar and then repeat. This happens to samples that i recorded for more than 1 bar. I cant figure out how to save the workspace in such a way as to preserve each bar recorders length.
Bar Recorder in a saved work space
you use one of the live kit sampleur ( if yes , which one..? ) or you've built your own...?
Im using the "Live Bar Recorder.pat" but i have modified it a bit. I thought I only made changes to relating to interface, but there are a lot connections i dont understand. When I get home test again with unmodified "Live Bar Recorder.pat"
