Can i use usine as a midi controller?
gearfreak
Unread post by gearfreak » 19 Aug 2009, 15:00
I have a funny feeling this is going to be a really stupid question. But...
I'm fairly new to production and i'm trying to link my wiimote to fl studio.
Out of all the software i have tried this is the only one i can get any output on.. i mean i can see all the wiimote data when i add it a interface control.
what i can't workout his how to output that data to fl studio. Is there any guides to do something like this?
With the built in fl studio internal controllers they show up in a list to link them to a controller. Is there any way to get this kinda functionality?
thanks very much!
James
gearfreak
Unread post by gearfreak » 19 Aug 2009, 18:44
Its ok got it working... the results are all over the place! but works non the less!
Thanks very much.. this is an amazing program!!
Clearscreen
Unread post by Clearscreen » 20 Aug 2009, 00:20
how were you linking them? midi, OSC? i haven't used FL so not entirely sure what yer doing here - sounds interesting though...
there is a list of assignments in Usine under the setup menu, 'global midi and key learn. you can assign midi by right clicking on stuff (faders etc.) in the interface builder or the track control panels. OSC's bit trickier for now as you need to set up Usine to receive the OSC then use OSC modules to capture it, interprete it and route it to where you want it to go. i've mentioned to senso that "OSC learn' would be useful but i'm guessing it's probably some where in the 'to do' list for the time being.
Users browsing this forum: No registered users and 518 guests
