Interface Builder - What determins which object is "on top"
skully
Unread post by skully » 02 Aug 2009, 00:20
I have a patch in which obects overlap on the screen. When editing overlaping obects, a click will bring the object to the top. After saving the workspace and reloading, some of the objects i left on top are now underneath, but are others are left like i want them. what actually determins which objects are on top when objects in the intface builder overlap?
Skully
Unread post by senso » 02 Aug 2009, 11:52
actually no way to adjust the Z-order of objects in the IB.
I hope that this functionality will be added soon.
skully
Unread post by skully » 02 Aug 2009, 16:56
I was able to fix it (work around it) be re-creating the buttons i wanted on top. seems that the order of their creation matters. The last object created remains on top.
Unread post by senso » 03 Aug 2009, 10:32
yes you're right.
