No MIDI ports with fireface800
oxyredox
Unread post by oxyredox » 27 Jul 2009, 11:53
I juste bought a fireface800 and it's working very fine with usine ; better than a Mbox mini, but what can be worse...
Yet I don't post here to tell you I'm happy (though I couldtalk about lots of thing I love about USINE) but that I have a problem : the MIDI ports don't show at all (should be 1 in and 1 out).
I've updated every possible thing from RME website but it's still the same.
And the problem seems related to USINE since the MIDI ports do show in Cubase.
Has anyone of you encountered the same problem or an idea about how to solve that?
I can't imagine that none of you has a fireface800 :)
thanks for your help.
Unread post by senso » 27 Jul 2009, 12:00
As I know there is no problem with RME midi ports under Usine (I have one and I know about 300 persons who use this card)
If the card doesn't appear in the midi driver list it can comes from a bad driver installation?
mondombe
Unread post by mondombe » 25 Feb 2010, 18:54
je viens d'acheter usine je voudrais looper ma guitarre sinthy et au meme temps conecter un FCB 1010 pour controler midi
est ce que s'est possible?
est ce qu'ils y a des courses a Strasbourg? Ou une reunion de usuaires de Usine en allemagne?
Unread post by nay-seven » 25 Feb 2010, 19:34
welcome mondombe
as you can notice , could be better to talk English here, cause it's an international forum..;-)
talking about fcb1010 and Usine no problem , all depend of your midi hardware..
about workshop , we're working on..don't worry
gurulogic
Unread post by gurulogic » 25 Feb 2010, 20:06
Just to be sure, you know the midi inputs are empty untill you select an interface from the pop up menu on each of the eight input options?
Users browsing this forum: Google [Bot] and 244 guests
