Same list in different samplers
noise2sine
Unread post by noise2sine » 24 Jul 2009, 07:52
I have a sample list about 25 samples and the weight of that list is around 790 mega and my Pc has 2 Gigas of ram. i'm using 4 different samplers set on the memory option. i want to load the same list in the 4 different samplers. Unfortunatly when i'm loadind the list in the second sampler, an internal error message appears !!! with the third sampler the same !!!! and then i can't play the project even loading it later. Whereas if i set the samplers on file it's working fine ??? can i have clues, because the storing in the ram option is the best solution for me !!!
cheers Usiners
Unread post by senso » 24 Jul 2009, 12:04
I know that I have to implement a better sample management: load a sample once even if it used several times in different samplers.
This behavior was implemented by the past in the earlier versions of Usine.
maybe it's time to reintroduce it.
noise2sine
Unread post by noise2sine » 24 Jul 2009, 12:36
Thanks Senso. I will wait for that option
Users browsing this forum: No registered users and 421 guests
