Trigger Audio Samples
How do you use usine?
soundprizm
Unread post by soundprizm » 16 Jul 2009, 20:03
Hey everyone,
I'm a drummer, and I'm trying to trigger audio samples live from my set. My setup is: triggers-->alesis dm4 drum module-->tascam us-1641-->laptop w/ Usine
I've been through the manual, and it seems to me that the only way to do this is by using the sampler module. Isn't there an easier way though? Maybe a module that I can just drag&drop the audio sample into and then midi learn the trigger? I'm a complete noob to Usine so all and any feedback is much appreciated.
Thanks!
Unread post by nay-seven » 16 Jul 2009, 21:18
hello and welcome
in global setup / interface , choose the dir you use for your sounds
then drag and drop your sound into a patch and choose " wave file player " in the context menu
now assign your midi learn to the play button...
that' s all...;-)
( maybe next time better place could be in patching forum... ;-)
soundprizm
Unread post by soundprizm » 17 Jul 2009, 19:01
Thanks nay! Worked like a charm... sorry for posting in the wrong section! :)
Users browsing this forum: No registered users and 64 guests
