long delay
blugaruda
Unread post by blugaruda » 16 Jul 2009, 09:30
Hi there,
Is there any chance of getting a 20 second, (or thereabouts) delay with tempo synch at some point in the future? The built -in one only goes up to 2 seconds. I have a long delay vst plugin but I can't type in the exact time delay for some reason, though I can with the delay modules that come with Usine. and I quite like putting signal proceesors in the feedback path..
g
Unread post by senso » 16 Jul 2009, 11:01
the maximum default value is 10 sec but can be adjustable up to 60sec with the MAX parameter.
if you are using a subpatch you can adjust the MAX values of inlets/outlets to any value you want.
blugaruda
Unread post by blugaruda » 16 Jul 2009, 21:16
Excellent! Thank you :-)
blugaruda
