pitch to midi module
Felix_Petrescu
It already exists as a patch (not directly as a module) and do a good job!
I tried it with bass and with guitar, the latency is correct and if you play clean it works really good. I think this patch is to be found in the "analysis" section.
Léo
if u want polyphonic recognition: very hard!
afaik there is only one plugin that can do this:
http://www.widisoft.com/english/mp3-midi-products.html // about 60$
if mono is ok, try the Usine patch, or alternatively:
Synodeia2 by klanglabs, or Junction by frettedsynth // free, i'd prefer the Usine patch here
Felix_Petrescu
thanks.
where is the usine patch ?
is not in analysis ...
are you sure...?
Felix_Petrescu
nay: sorry
i'm at job and i didnt had Usine installed here.
i thought you pointed for addons area
my fault !
my fault !
no fault here...
Users browsing this forum: Google [Bot] and 13 guests
