audio file player
blugaruda
Unread post by blugaruda » 13 Jul 2009, 07:54
Hi there - again!
I can't seem to find a module that will play an audio file once and just stop. Any suggestions?
Blugaruda.co.uk
amiga909
Unread post by amiga909 » 13 Jul 2009, 08:24
- u can do it with the sample module.
for example: use the 'end' or 'pos' outlet with a logical module and control the start/stop behavior in this way
- load a wav in the sequencer
- use an external sampler vst and build ur own interface with usine
iococoi
Unread post by iococoi » 13 Jul 2009, 09:03
hi there..
just use a sampler (audio->samplers) and set sync mode to play button. hook up a button to the play inlet and that should do the trick...that is, if you want to keep it really simple :]
cheers,
io
blugaruda
Unread post by blugaruda » 13 Jul 2009, 13:49
Thanks again guys. I notice that the sampler module is limited to 6 mins playing time so decided to use a plugin instead. I'm playing along to a number of pre-recorded "spines" btw. The more I delve, the more I'm excited by the possibilities but I need to get my set up and running under usine and check it's stable yet. It's crashed a couple of times while I've been messing about with patching though no problems when it's actually doing it's thing while I'm doing my thing, so to speak...
bugaruda.co.uk
Unread post by nay-seven » 13 Jul 2009, 14:20
just to let you know : the sampler modules is limited in record time , no playing time..;-)
you can play / load the sample you want..
Unread post by senso » 13 Jul 2009, 16:12
right nay-sevent.
just for info, the max record time of the sampler module is 10 minutes.
I think it's sufficient for most live sampling?
but can be increased easily if you feel limited.
