Object Pallete
Dozius
Unread post by Dozius » 26 Oct 2006, 22:28
I think it would be handy to have the modules/vst/library/sound menu items put into a floating 'pallete'. An included search dialogue for the pallete would be really handy as well. Bidule has this and I find it speeds up my workflow a great deal not having to always open menus. Also having the search if I forget where a specific module is located in the tree structure saves me alot of digging at times.
Just an idea I think would help.
Unread post by senso » 27 Oct 2006, 08:40
It's a good idea.
More generally, I should improve the browser: organisation, display file info, etc.
thanks for your feedback.
Users browsing this forum: No registered users and 115 guests
