New version (2.4)
Announcements
Unread post by senso » 25 Oct 2006, 17:11
New features:
-fade in/out on Mute/solo/onoff of the track mixer
-grain-sampler module (change the speed of a sample without affect the pitch) [see new examples in the add-section]
-array inlet/outlet in step modules
-append button in conductor lite panel to memorize scenes quickly
-menu Edit/Delete
Fixed bugs:
-some VST parameters aren't visible in the patch (posted by lalo)
-aux send busses order (posted by lalo)
-problem with some VST's in the preset manager module
-export wav files in sub-patches
-array?s memorization in conductor recall
-send midi out problems in Patch Remote Mode assigned midi channel
mahtazz
Unread post by mahtazz » 25 Oct 2006, 18:19
Thank you, Olivier!
bobsled
Unread post by bobsled » 25 Oct 2006, 19:33
Mmmmmm...yummy new version. Thanks!
Users browsing this forum: No registered users and 116 guests
