Usine 4.22b update
Announcements
Unread post by senso » 10 Jun 2009, 09:47
[4.22b]
intermediate update. You can skip it if everything works on you system.
fixed bugs
- small scrolling issues under Windows7
- global synchro problems pianoroll module: the cycle synchro doesn’t work properly
ethnix73
Unread post by ethnix73 » 10 Jun 2009, 09:54
Thanks Olivier for the fixed bug about the cycle mode for the piano roll!
Seb.Dub
gercha1
Unread post by gercha1 » 11 Jun 2009, 21:00
thanks for your job
it's a great tool
oxyredox
Unread post by oxyredox » 16 Jun 2009, 21:14
hi,
It seems like i need to post a reply to be able to create a new topic so I use the occasion to check on new updates and to congratulate Mr Sens for the great job ! (I did'nt found time for it cos I was too busy having a great time with USINE :)
Users browsing this forum: No registered users and 25 guests
