My hard disk crashed last week
So i lost a lot of things
One important thing i lost is my activation code to unlock the sequencer
Can you send me it please?
Thanks a lot
It is currently 27 Nov 2026, 09:18
Unread post by headphoner » 25 Oct 2006, 16:17
Unread post by senso » 25 Oct 2006, 17:23
Unread post by make » 09 Dec 2006, 12:07
Unread post by senso » 09 Dec 2006, 15:46
Unread post by allofdrab » 07 Dec 2010, 17:41
Unread post by senso » 07 Dec 2010, 18:54
Unread post by barrydillon » 19 May 2011, 10:20
Unread post by nay-seven » 19 May 2011, 10:38
if you have tried the free version, consider the pro version with more in/outs and functions ( sequencer, conductor, ability to use the poly function ...and so..) , as described in the implementation chart.1. What is the difference between each of the three different versions of Usine, ”Usine Free, Easine, Usine Pro ”, the implementation chart, while listing the functionality and features of the different versions, it does not make clear, what each of the three different versions, are for?
pro one with a cool price2. Which is the version is the specific “Educational Version”.
correct !1. I sent you a scanned copy of my TCD student card (both sides) and email (what is the email address I should use for this task?) it to Sensomusic.
2. I then use “PayPal” to pay the €60.00 to Sensomusic, as payment for the copy of Usine.
3. I then download the Usine Pro version of Usine.
contact@sensomusic.com as indicated on the buy page : http://www.sensomusic.com/buy/(what is the email address I should use for this task?)
Unread post by Martin_Tanton » 08 Mar 2018, 17:50
Unread post by nay-seven » 08 Mar 2018, 18:06
Unread post by nay-seven » 22 Sep 2018, 08:30
Return to “Registration procedure”
