Hello there ...
I'm back into pacthing and I've a problem ...
I buit a sampler to loop from a certain position (let say 60%)
so I plug a fader into "pos" inlet of the sampler with a "pass even flow" when pressing play
When I press play, (sync mode to "play button") it starts playing from the position 60%, OK
then when it plays (is playing), the sync mode turns to "loop", OK
When I press stop, the sync mode turns to play button and it stops, OK
but first time getting to loop (sync mode) is ok and it starts from 60%
and the next time getting to loop sync mode) makes my start position to 0% ...
I don't understand why ...
I tried to delay (few ms up to 2000ms) the changing of "sync mode" and it's the same, one time it goes from play button to loop softly and the next time when it pass to loop it restart from the begining ...
Is there a solution ?
Thanks (hope I'm clear)
About samplers and sync mode
Houps !!
Sorry ... I simplify my patch and it works ok ...
(smetimes having to explain help to simplify)
so it works fine
so it works fine
- nay-seven
right !(sometimes having to explain help to simplify)
