Input type
Gizzeta
Unread post by Gizzeta » 20 May 2009, 11:47
How can I create an input like in the A*B module?
I'm saying an input without prefixed limits and if there's no cable connected I can double ckick on the module and type a number in.
I tried with a DataField type with ReadOnly false, but the number is not stored in the field.
Unread post by senso » 23 May 2009, 22:31
sorry to answer so lately, I was on the road
you can set
ParameterType = ptDataField.
also set
in the
<float.h>
they are several definitions
#define FLT_MAX 3.402823466e+38F /* max value */
#define FLT_MIN 1.175494351e-38F /* min positive value */
so you can set your parameter to
minValue = FLT_MIN
maxValue = FLT_MAX
Gizzeta
Unread post by Gizzeta » 24 May 2009, 15:24
Nice, thanks,
the other problem is that I can't see the value stored in the module, I only see the caption of the DataField...
