Phase Vocoder Pack
Phase Vocoder Pack
by senso Posted on 2009-05-12 15:11:33
The Phase Vocoder Pack opens a new area in spectral manipulations in Usine
Contains:
- FFT forward module using the Phase Vocoder algorithm, transforms the input sound into a set of two array’s, one containing the frequencies and the other containing the amplitudes for each frequency.
This module allows frequency manipulations.
- FFT inverse module to provide the transformation from frequency domain to time (audio) domain.
- ArrayDelay module which delays each incoming value of an array according the delay input values (stored them self into and array). The delays are set in ‘number of audio blocs’.
- Pich-Shifter example using FFT forward and reverse. This patch provide a higher quality that the original library version. Unlike the classic FFT version (see Spectral in the Library) this Pitch-Shifter preserve the tonality and can be used for a transposition of a musical instrument.
- Spectral-Delay example ready to use made with the ArrayDelay module.
This work is my first User Module in C++ and can be improved and optimized; those versions aren’t CPU friendly.
Based on the great job from Richard Dobson http://people.bath.ac.uk/masrwd/pvplugs.html
The source code is available in the wiki page.
Contains:
martignasse
hey man,
Serious toy you made here
result are so.....spectral
and you said you don't know C++ hehe
@martin: I've just made a copy/cut from your template!!!
you can take a look and try to optimize it?
martignasse
It's made for that, note that you are my first customersenso wrote:@martin: I've just made a copy/cut from your template!!!
But it's little more than a copy/past :rolleyes: i see some asm in there. and the FFT sources seems like a mess, at first look
It's exactly what i'm doing now (looking in)senso wrote:you can take a look and try to optimize it?
Before optimization (if i can do something at this level), i propose to reorganize projects and solution files.
We have to think about a global way to publish these little jewels.
I think individuals project for each user modules is enough (like the Display Number and the Roll Array) :
- If we open just the vcproj file, VC construct automatically a solution for it (Good for instant access and compile)
- We can also open them in an existing solution, like explained in the wiki (Good for more deep studying and compare with other modules).
PS : the first optimization could be to compile them in release mode
Clearscreen
FANTASTIC!
Excellent !
Spectral delay remind me this plugin : http://www.artificialaudio.com/pluginmenu/2
I'd like to emulate it in the past in usine. Now it's really possible !
hello!
i have to admit i still have to learn how to deal with arrays...so here's my question: am i wrong if i think that i can use the output of the FFT forward module to do some resynthesis on the input sound (for example enhancing some frequencies, splitting the input sound into different bands etc), to find the fundamental frequency and maybe to generate a set of sine waves using the frequencies in the array??
BTW pitch shifting sounds pretty good!
Ciao,
Goyya
Ciao,
Goyya
goyya76 , i'm sure there's many things you can do this way , but maybe better to add a new post in "patching "questions to have help if needed..?
Nay i guess you are right - i'll do some trial&error then re-post in the patching question to share (hopefully!)...
updated, now compatible with Usine 4.22 or higher.
one modification could be useful : frequency range fader to make FFT not for full spectrum of 44400 Hz but for example from 0Hz to 500Hz but with full resolution (512 elements in arrays). now this frequency range is represented by just a few elements in both arrays.. im thinking in good way? its possible? I dont now much about FFT techniques...
actually not really possible since the FFT is 1024 length.
probably in futures versions of usine
Hello Olivier
thank you for this fantastic tool with source !!
I try to make a transposition directly in PhaseVocoderForw and i saw that there is a function that seems dedicated :
pPrototype->ptran->tickTransp(float semitones);
But i can succed to use it, is it complicated to use ?
i try to put something in the process loop like that
while(--sampleFrames >= 0){
pPrototype->ptran->tickForw(*in1++);
sampleFrames = FFT_SIZE / 2;
pPrototype->PAmplitude->len = sampleFrames;
pPrototype->PFrequency->len = sampleFrames;
pPrototype->ptran->tickTransp(6);
*amp2++ = *amp1++ ;
*freq2++ = *freq1++;
It doesn't work but, since the transpose function like what you did in the pitch shifter.pat modifies frequencies and amplitudes arrays lenght (sampleFrames), i suppose this function take place after the determination of sampleFrames. the way i use it is perhaps a non sense code speaking but i am not fluent yet about pointer manipulation.
*amp2++ = *amp1++ ;
the phase vocoder pack is separated into 2 modules:
- transform forward
- transform inverse
to create a pitch shifter, try to mix both of them, using the 'pitch shifter.pat' example.
forward ---- expand array ----- inverse into the same process loop.
- transform forward
- transform inverse
yes it's what i will try to do but since there is a pPrototype->ptran->tickTransp function i was wondering if it wasn't dedicated to transpose
I don't remember exactly how it works but you should take a look on the original source code of the plugin here:
the original works as a 'normal' shifter.
Users browsing this forum: No registered users and 74 guests
