Is there's a way to update the "file" output of the sampler when the list has change ( new file record, or new playlist)?
when you wire to this pin a combo-box, the names of the files appears in the combo-box. But if the list of the sampler has change, this is not update.
Is there a way to do this? Is possible with ILM?
Thanks.
A way to update the sampler 's file list output pin
i suppose if you use a "has change " who send a message as
delete_module
create_module
create_link
sorry no time to test right now..
delete_module
create_module
create_link
how do you do that? what are ILM ? is it working?
(someone interrested...)
ILM is Internal Messages Language - check the manual. It's a kind of scripting language to create or delete modules and connections, get/set values etc.
Check the manual!
Check the manual!
