My first try...my first headaches :)
fractal
Unread post by fractal » 10 May 2009, 20:49
Hello Usiners !
After using Usine for Midi, i try it to build some(thing) audio add-on.
My first try is make some Molar/Mlr like add on.
here some links for info/video:
http://www.youtube.com/watch?v=qPqTdOERX3c
http://www.youtube.com/watch?v=hsYcLnGm ... re=related
Ok, now my first problem...
I try to assign a start position and a end position to a button.(i make this for 8 button,this cut the sample in 8 part)
For the start position : ok (i put a A*B with the value on B after the button to "Start "of a Sampler)
When i make the same thing for the end position , the end position go directly to 0...i know i miss something...but what...
Other thing, it's possible to put the "loop" mode on sampler and only play the loop when you push the button(one of the 8)?
I know it's not very clear(in my brain it's super clear :) )
I try to put a screen maybee this night.
Ps : and yes Nay-seven i'm goin to upload the photo ;)
martignasse
Unread post by martignasse » 10 May 2009, 21:02
wow, you are not beginning by the simplest !
If i don't misunderstood, the first step is to 'cut' the sample in height (or more) equal part ?
so, maybe you should look at markers of the wavedisplay ?
gurulogic
Unread post by gurulogic » 10 May 2009, 21:08
Hello fellow Monomer! Sorry I don't have any answers for this problem but it's great to see someone try to use the Monome to control Usine...
fractal
Unread post by fractal » 10 May 2009, 21:22
In fact i'm goin use it with my touchscreen :)
I just want the button send a value to start and end position...for the start it's ok but for the end...this doesn't work with any value(the sampler go crazy and put a 0%= no sound...)
thank's for the reply guy's ;)
martignasse
Unread post by martignasse » 10 May 2009, 21:59
maybe something like that ?
mlr_test.pat
where you control the start pos and end pos of the sample with the range display ?
fractal
Unread post by fractal » 10 May 2009, 22:11
Not exactly that martin but great idea :)
I find how put the value for the end position.
i put here the base idea :
http://www.sensomusic.com/forums/upload ... 0FINIR.wkp
every one is welcome to improve this ;)
Unread post by nay-seven » 11 May 2009, 14:17
just try it , works fine , you can also add a knob linked to the first B+ and the secondB* ,
the second B+ and the thirdB* and so ...to set easily the markers..
btw , here an other way , give by senso for a request on a other forum...
http://www.sensomusic.com/forums/upload ... rsion2.pat
not exactly the same but can interest you...;-)
Unread post by 23fx23 » 19 Jun 2009, 19:18
hey fractal still on air? ive tried to build a basic mlr that interest me too, here is a simple pach with the basic idea:
no markers,
a local sync play the 16 step in order, if you press a pos the sync is reset and start from this pos, as there is a A mod B if reached the limit restart, quite fun. maybe can interest you...
http://www.sensomusic.com/forums/upload ... le=MLR.pat
im thinking of implementing a variance to the square,if using hardware sampler/other soft dealing with rex type files made with 16 markers could make a midi version that would automativally trigger good sample..and be compatible with any sampler.
on the otherside usine can be really powerfull, maybe trig the mlr loops from usine, don't know...
note i tried here with 16 step for 2 bar loop.
i wonder if would note be better the sample continue where it "should have been" when the step modified are finished playing, how is it on your mind relating mlr?
Users browsing this forum: No registered users and 50 guests
