a couple of bumps
Unread post by woodslanding » 08 May 2009, 10:24
Mentioned them before, but still waiting.....
1. Combobox for conductor presets
2. Combobox for vst presets
Some way to have these stay updated (can't use comma text for large preset lists.....)
I need to be able to write new presets for my vsts, without having to recreate a bunch of the gui!!!
And I need to select (and see!) conductor presets from the touchscreen. I don't always play songs in the same order, and sometimes I just want to look for sounds.
please, please, please!!!
cheers,
-e
Unread post by senso » 08 May 2009, 16:21
this new feature is not a pb to implement except that the actual engine of Usine has to be modified to handle events with a length greater than 512 elements.
And it could be a fast job but I take tho occasion to modify the engine deeply in order to implement un size-limited events.
so I need time.
Unread post by woodslanding » 09 May 2009, 07:47
okay, I am patiently twiddling my thumbs.
so will comma text actually really work in both these instances??? I guess so?
great, thanks!
-e
p.s. any idea how long this upgrade will take? weeks? months?
