Here's an example of a 3x4 stereo bus routing matrix with semi automatic delay compensation
to correct audio phasing caused by sending a parallel audio stream to a bus. This patch is also perfectly suited for compensating for any additional delay caused by vst plugins that are inserted in the routing matrix.
Addons --> Other
(this is made in 4.2, beta 11 so it may not work properly on earlier versions?)
3x4 Strero Bus Matrix+Semi Auto Delay Compensation
- senso
yes+++
