rotate screen
Unread post by 23fx23 » 26 Apr 2009, 15:48
Got a mpb 15 with radeon X1600, formatted and installed W7. after a little fight got all my audio gear setup working nicely, plus the touch drivers of my layer. cool. unfortunately the mpb is not designed like a tablet pc, and you can't return the screen ;)
..so the pb is, that in the normal laptop position, I got a little spring effect when pressing, releasing the touch screen wich can create unwanted touch interpretations.
I thought I could turn the laptop 180° in both way so the screen could be solid put on the floor while keabord on air, and touch is so much accurate. But then I need to rotate 180° the whole desktop, no pb
I go to the ati driver and try to rotate....
...no such option! arf, don't why apple locked the driver like that Im not able to download a driver directly from ati. managed to install an old one with the option there but doesn't do anything if enabling :(
any ideas? is there other way to rotate screen via software? ( or should i all inverse my interface items, ouch...)
fractal
Unread post by fractal » 26 Apr 2009, 16:48
hummm,,,,
Are you under Win7 or via some virtual machine?
(under Mac ,sorry i can't help you...)
Unread post by 23fx23 » 26 Apr 2009, 17:31
yup im on w7, seems there is a tablet option to natively rotate but as the mac hasn't the hardware swich im blocked, arf
the workaround is to put something heavy behind the screen, not the top hehe
Users browsing this forum: No registered users and 334 guests
