tx2500 performance vs desktop
gurulogic
Unread post by gurulogic » 24 Apr 2009, 18:54
I've just run Usine on my relatively new tx2500 tablet for the first time (my last laptop suffered an unfortunate electrical accident, RIP), and I am finding the cpu use vs desktop is much higher than I would expect.
The default workspace that loads with Usine (4.2 beta8),running uses between 45-55% of the dual core AMD QL-62 2Ghz cpu with all Usine settings default, except for the multi core 2 threads setting.
The same default workspace loaded and running on my intel core 2 quad core 3.5Ghz desktop with all Usine settings default, except for the multi core 2 threads setting (for comparison sake I am not using 4 threads) uses 1-2% ! (x2 = 2-4% of two cores)
Lets say that my desktop is 3x faster than the tx2500 while using only two cores, that should still only amount to 12% or maybe even 15- 20% cpu running the same workspace on the tablet, but 45-55%?
Both computers are using the same audio hardware, PCI Express/Expresscard > RME Multiface II set at a 256 sample buffer.
The desktop is running Windows XP 64-bit, the tablet is running Windows 7 evaluation/beta.
Could this big of a performance gap be because of Windows 7, or are the AMD cpu's really not very efficient?
I assume there are at least several of these tablets in use around here. What results are you getting?
Unread post by 23fx23 » 24 Apr 2009, 19:29
I guess yes, but is the laptop alimentation settingz set to "always active", can do a lot.
seems disapointing results, sad truely nice otherwise, I hesitated to buy one, I finally got back a cheap layer for mbp 15"..
edit : arf and im just about to install W7 beta...mmmm
Unread post by 23fx23 » 24 Apr 2009, 23:00
..so just installed W7, first impressions: quite fast and responsive, touchscreen feel much better, seems very good
4.2 demo gives me 30;40 cpu average in 512ms asio4all on dual 2.33, saddly didn't check before on XP.. quite high also..
edit: on ableton live results seems same between Xp and W7, had a liveset at 50 percent still the same.
gurulogic
Unread post by gurulogic » 25 Apr 2009, 00:05
I guess i'll just have to trim the fat for the little ultra mobile setup I have in mind. At least I should still be able to keep lots of stuff preloaded in RAM.
fractal
Unread post by fractal » 25 Apr 2009, 12:11
Hi Gurulogic !
I have the same result on my TX2Z...
I think it's the AMD processor...(and my fan sound like an airplane! very scary sometimes ahahah)
Anyway , i can run Usine ,Ableton 7(with a lot of reaktor5 hungry plug) and Audiocubes software quite well (sometime some slow touch...)
Unread post by 23fx23 » 25 Apr 2009, 17:27
it's crasy we still so easy ruin cpu on modern laptop when making sound..still have to be very carefull..
gurulogic
Unread post by gurulogic » 25 Apr 2009, 18:27
30-35% on my gf's core 2 dual 1.8Ghz Vista bogged down laptop. I see a clear winner hear. Just for fun I made 10 copies of everything in the Welcome patch and managed to get my desktop to use a whole 26% of two cores..! So GHz-Ghz, my desktop intel is apprx twice as fast as my gf's intel and no less than 5X as fast.per cpu Mhz in the Usine test... Can my fsb 1800-ish and faster ram really make that big a difference? It still seems unproportional to me...
80skeys
Unread post by 80skeys » 15 May 2009, 23:15
As an IT person, one of the best things you can do on the OS/software side, is the following:
Start > Run > msconfig
Services tab > Hide all Microsoft services > Uncheck everything you don't want/need
Startup tab > Uncheck everything you don't need
Just my two cents, it might help someone
Regards,
80skeys
Users browsing this forum: No registered users and 380 guests
