repatch multiple cables
Time and time again I am having to change a module with lots of cables connected to it or delete many cables...one by one..
It would be a great time saver if I could click on a connector pin and drag and repatch to a new location all cables connected to the pin or even just drop them in an empty space to delete them all...
Sometimes alt/dragging a new module/vst onto a highlighted module/vst works for this but usually I end up with the cables on the wrong pin or going nowhere.
+1
or something like: hold a key while dragging a cable and Usine would connect all outlets<>inlets of 2 modules. example: u have a stereo audio out and ALT+drag to a mixer module would connect both audio wires at once.
+1 for ALT+drag
Seb.Dub
Clearscreen
+1!! i'd also like to be able to drop a modules/vst on the square on connecting wires and have usine auto connect those wires each side of the dropped module/vst...
Is it a coalition?
I plan to create the possibility to move wire easily.
I hope soon.
I hope soon.
Clearscreen
it's a mutiny!!
look forward to what you have in store...
It would be also provide a faster patching to be able to select an outlet (for example with CTRL+ALT), and then until you release CTRL+ALT, each time you click on an inlet, a wire is created.
Seb.Dub
This is an old topic and for awhile in v4 we had the ability to drag a wire from one on to another on the same module, but now this is missing in v5?
Also I am very much wanting sometimes to easily move wires from one sub patch or module to another. This would be such a time saver!
So....bump goes this old topic!
Users browsing this forum: No registered users and 68 guests
