hello
it would be great to acced to samples not only with next/prev and next rand button but also with absolute position
value :1 -> sample 1
value :2 -> sample 2
or with midi but it would probably reduce the choice to 128.
the same function coud be usefull on grain re-sampler.
thanks
absolute sample choice in sampler module
Plane Pamal
- New member
Hi Pansoul
you can use the sampler's list and choose the file you want directly in this windows
or use the 'file' input of your sampler module and recall a value.
wow !
perhaps i should not ask question before 10 a.m
thanks a lot
thanks a lot
no problem!pansoul wrote:perhaps i should not ask question before 10 a.m
Feel free to ask any question, even if the answer is simple, it helps me to feel global perception of users and find a way to be more clear in the manual for example.
Usine mustn't be only for experts...
