WKP-OLD hope !!
noise2sine
Unread post by noise2sine » 02 Mar 2009, 01:39
hello,
i was working in a workspace,and at the moment i can't reopen that workspace. I really need to get back some patches inside.
how can make it ? what is the wkp-old file ? how can i open it ? would it be usefull for gettinfg those patches back?
Cheers !!
Unread post by nay-seven » 02 Mar 2009, 07:40
yes , just rename it as for example test.wkp and it will open , in the file/ temp dir you can also found some undo patch , save them in an other dir and try to open them...
good luck
noise2sine
Unread post by noise2sine » 02 Mar 2009, 12:47
thank u so much !!!! yr oscillator pack is awesome !!!!
Unread post by nay-seven » 02 Mar 2009, 12:51
cool
and thanks...;-)
Users browsing this forum: No registered users and 1522 guests
