Making Usine to remember the screen position of VST windows.
FarfadetFarfelu
Unread post by FarfadetFarfelu » 28 Feb 2009, 04:05
I use a lot of VSTs in Usine, and it's really useful to be able recall the VST GUI windows automatically when i activate a VST plugin so that i can tweak things and visualize what's happening in realtime. So far so good.
I like to position the VST GUIs on the right of my screen, the problem is Usine doesn't seem to save the last screen position of the VST windows into the workspaces.
When i load my projects and recall the VST windows (with a switch connected to the SHOW pins), the VST windows just pop out anywhere randomly... and i have to reposition everything each time.
It seems a lot of programs (including Bidule) automatically save the position of VST windows into the projects... so i guess maybe it could be achieved is usine ?
Sorry if this is already on the "to do" list. :)
Unread post by senso » 28 Feb 2009, 09:46
It use to be like that by the past and normally the vst positions should be memorized.
I'll take a look.
Unread post by senso » 28 Feb 2009, 22:35
pb solved, next release
Users browsing this forum: Google [Bot] and 13 guests
