how to "fix" to 1 the output of a peak follower, instead of....
goyya76
Unread post by goyya76 » 08 Feb 2009, 20:24
....having a one shot 1 value that returns to zero?
I'm trying to build a patch that outputs a constant "1" unitl the audio input goes below a threshold...apart from the peak follower, I tried with a simple A>B module, but it seems that the output value is re-calculated each Usine cycle (so i have a train of 1-0-1-0 etc) - a peak follower output a "pulse"....since a led connected to the A>B module output is constantly light on until the condition is true, i thought to use the led output, but i think it simply passes the input....
Hope i've been clear enough! BTW, the purpose of this patch is to activate the "HOLD" button on Ambience (a VST reverb - needless to say i guess for many ppl here!)
thanks in advance to everybody!
Goyya :)
Unread post by nay-seven » 08 Feb 2009, 20:34
have you try the track ( not in the audio direction ) of module like pass if changed or has changed...?
Unread post by grego mondo » 08 Feb 2009, 21:26
I can't remember how I did (and can't look in my usine at the moment) but I builted something like that from the gate patch ... so this can be one of the ways to do it ... good luck
Users browsing this forum: No registered users and 35 guests
