I need to do something very simple but i can't find an easy way to do that !!!! :
IF A = 1 (switch ON) SEND 2
IF A = 0 (switch OFF) SEND 0
so simple .... but i need help for that, because i can't find a module that send an integer if the condition is true, and an other one if the condition is false ...
Perhap's there is no easy way and i need to build a patch for that ?
thank you
If...then...else
- cmodica
Oh !!! So simple !!! So logical !!! But i didn't think about it ....
Thank you very much.
