conductor
plush
Unread post by plush » 28 Jan 2009, 21:03
visible on/off interface builder switches are not memorized in 4,1beta10, anybody else having this problem? Makes it difficult to use multiple patches with touch screen. Any solutions or work arounds much appreciated.regards Steve
Unread post by nay-seven » 28 Jan 2009, 21:36
have you check the " Tabbed panel example" ( first version ) patch of martignasse in addons/others/..?maybe can do the job..
plush
Unread post by plush » 29 Jan 2009, 15:48
Thanks nay 7. I have difficulty understanding the patch you suggest to transform it.
I tried conducting patch on/off which would be a good solution but the patch is still in the interface builder even when it is deselected or off, unfortunate on that point. Toggle won't work either obviously. Need a simple idea or maybe senso can fix that, I guess it would be classed as a bug,no? I noticed it was supposed to be fixed in beta 6 or 7, not with my version 10 in any case.
It seems quite important feature in a live situation with lots of different song settings when tightly arranged, not a hinderence for me when I do an improvised set at least.
Thanks for reading, happy to read any other suggestions.
regards steve
Unread post by senso » 30 Jan 2009, 17:59
thanks , i'll check as soon as possible...
