I think I miss a basic understanding relating with the pass/stop envent flow,
so ive understood that the incoming value pass/stop when activated, but whats going when it don't pass:
does it send nothing on output or (-1), and...
2) is there a way to get in a module the last "passed" value to keep on being active? (values that are red when not passing)
Ive tried to deal with a counter to get the "max", but it seems a bit messy in my purposes, and i feel there must be a much simpler way to get this...?
data flow question
- nay-seven
try to put a fader ( with good min and max ) behind your pass/stop , you'll see that only the last value is here when you stop23fx23 wrote:I think I miss a basic understanding relating with the pass/stop envent flow,
not sure i understand about " (values that are red when not passing) " can you explain..? an example..?2) is there a way to get in a module the last "passed" value to keep on being active? (values that are red when not passing)
that's it, so simple !!! thanks naySeven, i was using too much data out, the fader is cool to set min and max and have a constant integer value, i knew it was a simple thing, but so simple (shame on me hehe)nay-seven wrote:try to put a fader ( with good min and max ) behind your pass/stop , you'll see that only the last value is here when you stop
