Quantize options.
moody33
Unread post by moody33 » 12 Jan 2009, 20:41
-I guess if it's possible to add the quantize function ,sync to the local sync modules? Hard to implement?
-Could be cool to have the quantize options on the preset selector too.
Unread post by senso » 12 Jan 2009, 22:25
try the 'quantize data' module in the /Synchro & time modules/ just replace the 'global synchro' module by a 'local synchro'. It should do a good job.
moody33
Unread post by moody33 » 12 Jan 2009, 22:39
ok thanks you
