Hi Olivier,
I noticed that when I upgraded from 1,18 to 1,19 I lost all my settings on the audio card, so I'm still on 1,18.
I'd like to move to Version 2,0, is there a file I can save with all those settings plus the tracks' ones ?
thanks
how to save ins/outs settings when upgrading
- senso
Audio card settings are compatible with all Usine Versions.
Just copy the Usine.ini, from your old folder to the new...
Don't forget that you can save several Setup's profiles in separate files. (Setup+menu "file")
