A couple of IML-suggestions
antwan
Unread post by antwan » 07 Jan 2009, 22:34
Here's my IML-wishlist so far, for this near-perfect tool:
1)
Ability to set target patch to be a certain sub-patch and then do IML-commands within that sub-patch.
2)
IML-created names (module names etc.) should maintain letter case and be case-sensitive.
3)
When creating a sub-patch FROM FILE using IML, it would be great if the loading-window (the big semi-transparent progress-bar window) would either not appear at all or would be something small in the top-corner.
4)
Would be great to have access to a module's layout settings via IML. For example:
- Create a switch module (currently possible)
- Set the switch's visibility to Interface Builder (currently possible)
- Position the switch at X:100 Y:100 in Interface Builder
- With size 150x30
- Using layout-preset 'Switch01'
These additions would certainly make my day... year.
Side-note:
I found out (pure luck) that there is also a DELETE_MODULE command but this seems to be undocumented.
Cheers,
antwan
Vincent
Unread post by Vincent » 07 Jan 2009, 22:45
Yes, yes, very good Antwan!
+1 for all
More about the loading window, it also sometimes hides other important VST loading windows (Altiverb, GVI...) so:
since it can be usefull to have it anyway, would it be possible to implement it in the trace window (just like the quantize warning)?
The start-splash can of course stay as is.
No?
vincent michel
composer & novelist
Unread post by senso » 08 Jan 2009, 09:10
The IML was designed for the template engine, so something simple.
I didn't realize that it could be so popular!
I can turn it into something more powerful
1)
ok,
2)
I'm not sure it's a good idea?
3)
I'll see if I can disable the progress bar. It looks easy but in fact it's not so...
4)
- With size 150x30
could be possible of course, but we have to fix a limit of functionalities?
Side-note:
It's a mistake. corrected
antwan
Unread post by antwan » 08 Jan 2009, 16:59
senso wrote:The IML was designed for the template engine, so something simple.
Yes, don't ignore the fact that you have created something ground-breaking :)
senso wrote:
2)
Well, this is naturally not crucial. You are right that there's a greater chance of coding errors when case-sensitive, but on the other hand I think we're quite used to it thanks to previous scripting work. Maybe we can leave this for now and gather more opinions.
senso wrote:
3)
I understand. But as Vincent pointed out there are several reasons why it's causing trouble when fired by IML. Because now it's not only happening while we prepare & patch but also during a live show.
senso wrote:
4)
- With size 150x30
My current opinion is that this addition would pretty much complete the required functionalities. Otherwise we will quite often end up in a situation where we can automatically create modules and wires between them but that does us little good if we don't see the results or get access to them as part of our custom interface.
senso wrote:
Side-note:
Thanks. Now everyone knows of it's existence!
I'm not only having fun with this I'm also getting clear-cut gain in performance. I've remade a patch that used to take 5-8% of CPU when sitting idle. After remaking it with help of IML (excluding the interface) it's down to 0.8-1.2%.
Best regards,
antwan
