Hi guys and hi senso!
the recent usine improvements are simply marvellous!!
i'd like to use the same custom konb and faders i use on my synthedit/syntmaker/maxmsp stuff...
they are stiched png done with the great KnobMan software...
is possible to use stiched images for knobs and faders in usine?
thanx
lalo
Custom Skins
Excuse me, lalo, but what means 'stiched'?
I'm actually working on some layout collections and I'm maybe missing something!
vincent michel
composer & novelist
composer & novelist
@ lalo , yes you can !
all Usine skin have been made with knobman...the only difference is that you have to choose .jpg when you export your stuff..
check in the " files/skin " dir
@ vincent : a stiched knob is a knob where all frames are on the same file /picture , check also the skin dir and you 'll understand...
you can also check the skin i've made in the addons section to see an example too..
Users browsing this forum: No registered users and 381 guests
