First impression
jean-marc duchenne
Unread post by jean-marc duchenne » 28 Jul 2006, 18:22
The sequencer seems to be incredible !
I like very much how a double click opens the corresponding patch and returns to the sequence.
Just a few requests and questions after the first try :
- horizontal zoom with the mouse wheel
- when using the vertical move tool, is there an option to keep the relative positions of the points after they are pushed on top or bottom ? (actually they are compressed)
- how to select several points at once ?
- an option to NOT compress the position when resizing a sequence. I love that they can be compressed but il would be also nice to have the points keeping their actual positions
Something that would be great for the future would be to drag an object from the right "inspector" on a user slot to connect it.
Sorry if my explainations are not very understandable !
Unread post by senso » 28 Jul 2006, 19:07
So Usine seems to work on you laptop... Good news.
Good suggestion, and easy to do.
Harder, but not impossible. I know, if you make a mistake, you loose your curve... I will find a solution
I think that it could be possible, soon.
I think that it could be possible too.
For me, the sequencer user interface, is a hard programing job. And I know that I have to improve some points like you suggest.
I have ideas for a easy way to connect curves to objects. I have to think about it.
Thanks for your feedback
Unread post by senso » 29 Jul 2006, 10:52
done, next release
done, next release
done, next release with the Ctrl key
Users browsing this forum: No registered users and 47 guests
