Copy/Past for SNAP conductor
cybercharles
Unread post by cybercharles » 26 Dec 2008, 13:46
Hi Olivier
Can we imagine to copy and past the conductor SNAP ?
It will be realy cool !
regards
Charles
t
Unread post by woodslanding » 27 Dec 2008, 00:06
can't you just select a preset and save it under a new name?
cybercharles
Unread post by cybercharles » 27 Dec 2008, 11:58
Hi
At the end I understand how to copy and past in the conductor !
So we can do it in that way:
clic "insert"
select the snap to copy
then select the new insert snap and clic rewrite.
Charles.
t
Unread post by senso » 27 Dec 2008, 13:47
igood suggestions
@cybercharles: yes good tip!
