why not make it configurable?
nelson
Unread post by nelson » 25 Dec 2008, 10:18
first :
why I can't choose between present behavior of input fields (double-click and then edit while mouse must be still over this field, and then confirm pressing enter) and something "mouse-independent". I and many people I know are patching sitting in strange posiitions with their laptops (on the bed, on the flour) and must do acrobatic things to leave mouse in one position while editing some values with keyboard. sometime I need to try many times to edit one value because mouse is going out the editing field
second:
why not to delete modules with simple press "delete" instead of "shift-delete" - its not fast-patching-friendly :)
maybe let user configure thinks like that - there are more like this I think
(sory for my english ;)
Unread post by senso » 25 Dec 2008, 11:21
nelson wrote:why I can't choose between present behavior of input fields (double-click and then edit while mouse must be still over this field, and then confirm pressing enter) and something "mouse-independent". I and many people I know are patching sitting in strange posiitions with their laptops (on the bed, on the flour) and must do acrobatic things to leave mouse in one position while editing some values with keyboard. sometime I need to try many times to edit one value because mouse is going out the editing field
It's a protection for the live.
I'll create an option in the setup to disable this option.
ok you're right
Unread post by senso » 25 Dec 2008, 12:24
me again
The 'hide on exit' behavior is is no longer implemented in usine. I've just realized that it's not really necessary now, with the timer implementation. (by 'timer' I mean that the edit box disappears if there is no activity after 5 seconds)
Actually there is a Windows conflict between the 'del' in an edit box and the 'del' in a patch, so impossible to replace the 'shift del' by 'del'.
nelson
Unread post by nelson » 25 Dec 2008, 14:55
where in other place could I found wishes-fulfilling music software? :) only usine... tnx
it will be working in next version?
Unread post by senso » 25 Dec 2008, 16:19
yes the 4.1 beta6
Unread post by SylvainT » 30 Dec 2008, 22:08
+1 for the "Hide on exit behavior" out
