transparent image and bitmap out.
moody33
Unread post by moody33 » 24 Dec 2008, 19:27
- Transparent images are only possibles with png or gif files. do you plan to add these options?
-Since the "steps " modules have a "small" bars option, it make possible to build pianoroll patches. But only in mono..If the stpes modules could have a bitmap out, then it could be possible to build a kinf of polyphonic pianoroll with steps modules. Isn't it?
moody33
Unread post by moody33 » 24 Dec 2008, 19:34
Another suggestions : array to bitmap ?
Vincent
Unread post by Vincent » 27 Dec 2008, 19:17
moody33 wrote:Another suggestions : array to bitmap ?
hi moody33,
For this, assuming your bitmaps are all the same size, you can manage with a fader.
Just make a bigger bitmap file with all your pictures in line *or* in column.
When you affect this bitmap to a fader, don't forget to set the right number of frames, then, when you affect a value 'n' to the fader, it shows the picture #'n'.
If your pictures are disposed in column, just set the 'vertical' switch to ON.
This is a fader used as a kind of array. It works with Controls that can manage multiframe pictures: 2 frames for switches, 1 to 128 for faders and knobs.
But, as far as I know, you cannot route this picture to another control.
vincent michel
composer & novelist
Unread post by senso » 27 Dec 2008, 21:54
the main pb is that transparent stuffs are very slow.
I'm still in test procedure to find the best way to do that.
I hope for that the future v5?
Users browsing this forum: No registered users and 156 guests
