I like the surround panner. It's quite a funny tool.
But it seems that I hear a tiny delay between L/R and sL/sR.
Since it is for multiphony, it has maybe no real importance, but I'm wondering if I'm using it correctly.
Basically, I use it in combination with LFO or curves on F/B Pan (Y axis), since L/R pan is done with a shuffler VST. And I route the output with my favorite 'Additional Audio Output' (downward in tracks order).
I set input to mono and connect only one Y axis inlet, is that right?
Any good advices?
Thanks!
Surround panner
vincent michel
composer & novelist
composer & novelist
normally it shouldn't.
the XY Panner doesn't introduce any latency.
maybe it comes from your configuration?
Hm, my configuration, sure. More probably my patch.
That's just a detail. I was wondering how it worked.
Ok, thanks.
Ok, thanks.
vincent michel
composer & novelist
composer & novelist
