Appreciated would be a little help with the double echoplexx and delays uploaded to add-ons. In need of a few additions and improvements but work great on live & in recording situations. Delay has a hold function which turns it into a loop, when the delay time is alterted the pitch should change, it does very cool, though bugs get into it, so when you return to the original delay time, the loop is no longer the same. Works really well on a short delay not so on the longer delays, tried different smooth settings I think it is more complicated than that. This would ultimately be an improved modulation of a digitech timemachine.
Now the double echoplexx enables a seamless transition from one loop to another, check it out. Would be great to have a sample restart or position 0% button added, can't get it to work, perhaps you folks think of other features to add.
Si qq s'interesse je peux repondre en français. Bravo Senso.
A+ Steve Argüelles
www.plush-internet.org
www.myspace.com/stevearguelles
delay echoplexx help
Hi plush,
Concerning the double echoplexx, one solution to have a sample restart:
Put a ramp module, and set min-max to 0 and 1.01. Then connect the ramp out let "out" to the inlet "sync mode" of the samplers in the echoplexx patch, and connect the ramp outlet "start" to the inlet "stop" of the samplers...You've got to adjust the "width" parameter in the ramp module. At home, i've got to set it to 8.80ms.
A little bit tricky but it works.
Seb.Dub
To restart the loop, just put a "from 0 to 1" module connected to the Pos inlet. Then connect your Restart button to the "from 0 to 1" module. Each time you press "Restart", the loop is retrigger. That's all and easier than Ethix's advice.
yes, moody33, better solution than mine....I will have a closer look to the "0 to 1" and "and "1 to 0" modules.
Seb.Dub
thank alot guys, will try that and repost the patch in add-ons steve
