Hi
It seems that when the waveplayer is ON there is an Audio clic bug even if the waveplayer is not routed on track and audible.
See you
Charles
Audio clic during Waveplayer background process
Yes the wave player is always running in background.
If you don't need it you can disable it.
If you have audio clicks try to change the setup/asio/buffer size to adapt it to your harddisk speed.
Users browsing this forum: No registered users and 439 guests
