Problem with sample rate
fabthesabre
Unread post by fabthesabre » 30 Nov 2008, 20:15
I have an E-Mu 1820m as soundcard, with all the drivers up to date. Within the driver, you can create some "workspace" and specify the sample rate that you want. So, my personnal preference is 96k.
My problem is that Usine (4.1d) doesn't keep this setting. I have tried several tips, (save the preference to another place, edit with bloc-note the file, etc ...), but each time I start Usine, it come back to 44k. All other preferences is keeped, except this.
For information, I haven't got this problem in any other soft (Reaper, Cubase, etc ...)
I have seen an old post with the same problem (last april), but it's said that it's solved.
Any idea ?
Fab
Unread post by senso » 30 Nov 2008, 21:10
your are right the version 4.01 doesn't keep sample rates settings.
But the pb is solved in the 4.1 very soon...
fabthesabre
Unread post by fabthesabre » 30 Nov 2008, 22:28
Ok, thanks for the good news !
Users browsing this forum: No registered users and 416 guests
