Hi Usiners
Is it possible to remote conductor scenes with the sequencer ?
If yes it will be the ultimate weapon to creat music with USINE
See you
Charles
Remote conductor whith the sequencer
Hello Charles,
I remote the conductor with smpte.
When you make a new scene with the conductor, you can choose a Time Code. In the sequencer, read the time you want to change the conductor and write it in the conductor. While playing, when you arrive at that time, the conductor will load the new scene.
It is very easy, but it doesn't work well sometimes. I thing Oliver is working on another way (safely) to remote the conductor with the sequencer.
Hope it help
Hope it help
- senso
yes your right Sylvain, in the next version (4.1) there a new column in the conductor to assign a line directly to a marker.
It will simplify a lot this kind of automation
cybercharles
Hello hello !
Olivier: I want the 4.1 version nowwwwwwwww ! I can beta test this new feature if you want ...ha ha ha
Thanks for your answers and your work.
Sylvain I will try your proposal this afternoon.
Charles
Charles
t
- Vincent
If I know what "Conductor" means, this interface says to me: "when you recall snap 2, the cursor goes to marker 3", and not "when you go to marker 3, that will recall snap 2".senso wrote:
Each parameter of the conductor is an action of the Conductor, yet, this new one, if I correctly understand, is a passive one depending on the markers.
That remains me that, long time ago, i've suggested an Interface Control/Module that says where the cursor is, which is the previous marker, which is the next one, and if these markers are normal or loop markers. That module could have be very usefull for many things, specially this: recalling presets (and why not scenes). With that module, no need to add reverse-logical parameters in the Conductor.
vincent michel
composer & novelist
composer & novelist
