Here is the tip of the year if you have troubles during the saving process or a big Usine Crash.
When you manipulate a patch all the Undo's and Redo's patches are stored in the folder 'temp'.
In this folder you will see all the history of you patches like
Sergio Slicer-Undo-774809.pat
This directory is cleared at the startup of Usine so in case of big troubles you can easily get your last modified paches.
But I'll implement very soon, a system to keep the history of patches to be able to retrieve the last (let say 100) used patches or wkp.
The Tip of the year ! (following the post "A 4860 Ko WKP")
- senso
