hello usiners ,
i'm looking for a way for starting "actions" responding to a conductor number selection.
for exemple, when i select conductor #2, a counter starts.
i thought about using midi bus but i don't manage to do it.
is it a way to do that ?
thx
some action after selecting conductor item
This is not neccessarily the most practical solution in all situations (depending on how you trigger the changes), but it should work when you want a trigger/button type of action:
Connect the Conductor's "num" output to A on a Math/Logical/A=B module, and set B to the value/snapshot number you're testing for. Then connect A=B to an Events Control/0to1 module, and the 0to1 to whatever you're triggering.
If it's something that should happen all the time a given snapshot is selected - like when using a switch - skip the 0to1 and use the output of A=B directly.
thx for your answer.
i understand what you explain but my problem is that i don't see where i can "connect" the conductor's num ?
is that a conductor module ?
(sorry i can't check cauz i had to log out to mac to send this message)
ok i found the conductor module in the interface control module
good thing
thx bsork for your help
good thing
Well, it was a bit stupid of me not to include the path to the Conductor module when I had included for the two others... (For other users that don't know where it is: Interface Control/Usine Panels/Conductor.
Hope you get things working!
Users browsing this forum: No registered users and 100 guests
